Hi all,
I wonder if someone can help with this?
Rhino-7 Behavior [Working]:
In Rhino 7, in a GhPython GH Component, I used to use an is_user_admin
python function to see if the current user had opened Rhino using the ‘Run as administrator’ mode.
This function used the System.Security.Principal
module and looked like this:
import System.Security.Principal as sec
def is_user_admin():
identity = sec.WindowsIdentity.GetCurrent()
principal = sec.WindowsPrincipal(identity)
is_admin = principal.IsInRole(sec.WindowsBuiltInRole.Administrator)
return is_admin
print is_user_admin()
This worked fine in the .NET 4 Rhino 7 environment. It returned ‘True’ if in admin mode, and ‘False’ otherwise.
Rhino-8 Behavior [Not Working]:
In Rhino 8 however, for some reason those properties are not available any longer? Now, when I query System.Security.Principal
I see only:
['GenericIdentity', 'GenericPrincipal', 'IIdentity', 'IPrincipal', 'PrincipalPolicy', 'TokenImpersonationLevel']
but no WindowsIdentity
, WindowsPrincipal
, or WindowsBuiltInRole
So:
- Is there a better way to check if the current user opened Rhino ‘in admin’ mode?
- Is there a way to still access those ‘missing’ methods in the new .NET 7 environment? I rummaged around in there for a bit but could not seem to find anything?
- I am assuming this change is related to the .NET switch, but perhaps it is cause by something else?
any advice is much appreciated.
Thanks!
@ed.p.may
Environment:
- Macbook 2021, Apple M1 Max
- macOS 13.6.1 (Ventura)
- Parallels Desktop for Mac 19.1.1 (54734)
- Windows 11 Home v 21H2 (22000.2538)
- Rhino Version 8 (8.3.24002.13001, 2024-01-02)
