I setup an animation of a watch, one tick per second. Now my client as me for an additional quick loop movement of a part (“riot”), but my ticks are not fine enough. How can I stretch the whole animation so that I can insert a short-time-loop?
Hi Micha,
Luckily there is the BongoScaleKeyframes command which changes the spacing between keyframes. Have a peek in the Help file (section Timeline Window Overview).
Luc
Thank you for hint. I thought all commands/tools are in the menu, but I see, there is more at the command line.
I tried it but had no luck. I choosed:
Choose option ( Object View Light Layer Document Content ): Document
Scaling factor <1>: 2
Scaling direction ( Left Right Both ): Right
But nothing happens. I need to scale anything at the time line to get more space between my keyframes but without too loose anything. Did I something wrong?
It works here - but my guess is that you’re not picking the right type option. What kinds of keyframes do you have? If you pick “Document”, you’re only going to affect Sun keyframes.
The problem is to find all animated objects. Some are at disabled layers or hidden or … . So it’s some times not easy to not to oversee something. Or is there a simple way to scale all object key frames at the same time without selection?
I will add something to do this. I’m afraid at the moment there’s no way to modify keyframes on objects that cannot be selected. However, if you make all layers visible, show everything and use SelAll, you should get it to work.
Don’t think so. And unfortunately the Animation Manager doesn’t allow multiple selection - Andy?.
I’m familiar the irritation of fiddling with hidden layers and objects. A hint is to install a keyframe at tick 0 making every layer and every object visible. The actual animation then starts at tick 1 hiding or disabling whatever is necessary. This way you can always turn to the keyframe at tick 0 in order to get a hold on every object.
You can first of all insert 1 tick at tick 0 (use BongoTimelineInsertTicks command). All keyframes (every type) are shifted right without making selections. Then you can install the basecamp keyframe for every object and/or layer. You can take your time to make sure you have them all. Maybe use the Animation Manager as a guide.
Finally the BongoScaleKeyframes trick can take place. Whew!
Don’t agree with ‘integers’ only. Also rational numbers (as is now) can be usefull in the use of the BongoScaleKeyframes command - depending on how the timeline is structured. Fractions can be used to scale down the timeline. The use of decimals is obviously optional.
Of course when a specific patch for Micha is made, that’s another thing.
