Whenever I try to embed a block or attach a file in Rhino,
the original textures from the embedded or attached file often get replaced by filenames like "rdk$0200-0200-1ECAA56E.tiff"
with the file path changed to something like:
C:\Users\user\AppData\Local\Temp\McNeel\Rhinoceros\V7\Texture$Cache$\rdk$0200-0200-1ECAA56E.tiff
However, I’ve confirmed that the texture images I used are still present and accessible from my NAS(folder path:Y:\MatiralArchive).
The original texture paths are valid and haven’t changed, so the images themselves are not missing or moved.
As a result, those texture mapping scales in my renderings become incorrect.
How can I stop Rhino from losing file path or auto-generating cached materials like this?
nathanletwory
(Nathan 'jesterKing' Letwory)
March 27, 2025, 11:43am
2
How do you determine that mapping scales are incorrect to this?
Perhaps share a 3dm with a single surface and a material that uses a texture image that shows this happening for you. If possible add screenshots of correct and incorrect results you are seeing.
Also please add the results of the Rhino command _SystemInfo.
Rhino 7 SR38 2024-12-3 (Rhino 7, 7.38.24338.17001, Git hash:master @ 97e36efa02d7f71638988290bb2d190fcf1b18c5)
License type: Educational, build 2024-12-03
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2070 SUPER (NVidia) Memory: 8GB, Driver date: 6-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.99
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-1-2024
Driver Version: 32.0.15.5599
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp "Datasmith Exporter" 5.5.3.0
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino7.Plugin.dll "Enscape.Rhino7.Plugin" 4.2.1.88
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp "VisualARQ"
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\BlockTools (9e35eeba-007b-adde-4a97-8899a2462691)\1.0.6585.39424\BlockTools.rhp "BlockTools" 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp "Tibidabo"
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\RhinoFileVersion\7.0.7703\RhinoFileVersion.rhp "Rhino 3DM File Version" 7.0.7703.19539
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp "Commands" 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp "WebBrowser"
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp "RPC"
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp "PanelingTools"
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp "IdleProcessor"
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp "Legacy Rhino Render"
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp "Alerter"
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp "IronPython" 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp "RhinoCycles" 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp "Grasshopper" 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 7\Plug-ins\BlockEdit.rhp "BlockEdit" 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 7\Plug-ins\NamedPositions.rhp "Named Position"
On the right is a screenshot of the original file, on the left is a screenshot of the inserted file. As a result, the map size becomes wrong,the name and path of the texture are changed to the texture cache, The image file size has increased from 2mb to 23mb.
nathanletwory
March 28, 2025, 4:32am
4
@cy.huang.archi does this still happen with all of your non-Rhino plug-ins disabled in a new file?
@johnc are you able to deduce what is going on here?
johnc
(John Croudy)
March 31, 2025, 4:53pm
6
@cy.huang.archi
Would it be possible to get a 3dm file that repeats this problem? Even better would be exact steps to repeat the issue.
Thanks,
John
