i want to make planar surface using two sets of curve in grasshopper, how can i achieve below result.
such a simple node, this will help me to offset the curve and use those two curve to make boundary surface. thanks Helvetosaur.
Connect the āOrigin Planeā to the Offset āPlaneā input? Oh wait, the curves have different tree branches when merged (two wires in the same input), as @Helvetosaur said.
No code, no help.
3. Attach minimal versions of all the relevant files
These terms have to do with data tree structures in Grasshopper. A somewhat complex but essential subject to understand for anyone who uses it. There are various tutorials out there.
Briefly, Graft will take each member of a flat list and make it into an individual branch; Flatten will take a tree (regardless of the level of branches) and put all members of all branches into one single flat list. This is important because Grasshopper uses data matching, and when the input structure does not match what the component is expecting, the results will be unpredictable or incorrect.
@Kalpit_3d Grasshopper is spelled with āssā
Sometimes āSimplifyā will do, no need for Suirify. And sometimes flatten wonāt do at all.
boundary issue_2023Oct3a.gh (10.0 KB)
The most important skill to learn about GH is how to inspect and match data trees.
