Grasshopper surface from planar curves
How make surface from planar curves and now extrude?
Boundary Surfaces
Thanks.
But it is possible only from curves drawing in rhino. How make this in grasshoper. I can’t find the right tool anywhere.
Same answer.
You missed this part:
3. Attach minimal versions of all the relevant files
Sorry, i have see only 5 lines of text. I will study it. well thank you
Grasshopper_otvory na offset1.gh (12.2 KB)
Grasshopper_otvory na offset1.3dm (3.8 MB)
Is this what you want to do?
otvory na offset1_2024Jan23a.gh (11.1 KB)
Why so far from the origin?
As always, it would have been much clearer if you had posted files when you started the thread.
I just didn’t know… next time I will.
I couldn’t find the solution anywhere in the tutorials, so thank you very much.
It’s often the case that there isn’t just one solution. Which part of what I did was significant? You were so close, which part blocked you?
Extract surface using multiple curves specified by parameters.
For example, like in rhino using the tool as in the picture or simply with extrude a selection of multiple curves into a 3D object
I’m a complete beginner in Grasshopper and also only self-taught in Rhino for a few years
