I have a minimal surface (output of kangaroo). When I use Weaverbird mesh thicken, or Weaverbird mesh offset, or even mesh offset components to make the initial minimal surface thicken a part of the thickened mesh has a problem as you can see in the image attached. please let me know how can I fix this. (the second image is the initial mush (Kangaroo output) to thicken)
Thank you. But the question is How ! Can you use your again?
Actually, I want to understand why the output mesh of Kangaroo has various normals and in this case, how can I simply fix the normals?
To avoid such a problem again, I need to understand what is wrong in my def.
Thanks again @laurent_delrieu
Hello
you can’t really fix the normal calculations. A normal is perpendicular to the surface. Your surface is distorted due to the way the ellipse are oriented.
One solution could be to replace all normal that are on naked edge with what you think is good. And offset the surface your self using deconstruct mesh and construct mesh.
For the side it is possible to make them with a loft mesh of the 2 polylines of Naked Edges.
And if you still have problem with normals, attractor could be used. For example
New “Normals” = Normals * (1-factor) + Vector * factor
Factor is 1 near the maked edges and decreasing after. It will no be as simple but seeing your definition you must understand the idea.
I appreciate you @laurent_delrieu
I see that naked edges could work properly; however, as it is obvious in resulted mesh, the problem still remains. I have attached an image here to explain better.
this ellipse section has this weird problem while the other ones are working properly!
Indeed, the naked edges of the main mesh are at the same plane (x, y, z = 8) and as soon as the offset mesh is made, we see the naked edges of the offset mesh are at different planes (x, y, z = various). it prevents me from having a clean mesh. This messy mesh is not good for fabrication and even presentation!
The problem is there depending of the offset you choose, as you have very thin faces problem is there at quite low offset.
I think attractor could work. So you will have a better transition between vectors.
You could also smooth value with my tool to smooth values on vertex (Nautilus tool), with fixed values on boundary!!
No smoothing
I appreciate you so much @laurent_delrieu
I was arranging the components to find out what’s going on. I need to check the code more and read more about what you told and suggested. If possible, I reach out to you in upcoming days to ask possible questions and to be sure that I got the points properly.
