Is mesh thicken to this complex form impossible?
Hi.
I made this single mesh geometry using kangaroo.
I succeeded in making a nice mesh, but i am having trouble in making the same version with some thickness. I’m planning to 3d-print it with some thickness, preferrably the thinnest possible…
Using weaverbird Thicken would make it go wrong.
I suppose it’s because of the sharp thorn-like edges, but I really need them to remain sharp…
Is there any way to maintain the structure intact and thicken the whole thing smoothly?
Thanks for any help.
mesh_kangaroo.3dm (5.2 MB)
sol_K2.gh (53.0 KB)
Hi @jmc.060691
It looks like your mesh has lots of problematic non-manifold and self-intersecting parts.
The grasshopper file you uploaded does not include the starting input mesh, but I believe the problem is starting there before the relaxation.
You can check a mesh using MeshRepair then clicking CheckMesh.
You want this report to say “this is a good mesh”
Alternatively, you can use the ShrinkWrap command in Rhino8 to thicken it into a solid, even if the starting mesh is bad.
oh. I started with 1000x1000x1000x mesh boxes, printed points to choose anchor points manually, then pressed start.
Maybe I have to deal with the naked vertices?
I tried repairing it, but it stops at some point without solving the whole thing… must be just as you’ve mentioned. Something wrong with the starting mesh…
mesh_add_original.3dm (7.3 MB)
I attached the file with the starting mesh I used, along with the anchor points I picked.
and since I haven’t upgraded to rhino8 yet, will the shrinkwrap command make the result porous (inside fully empty)? Maybe I’ll need to buy rhino 8 myself… because I’m using my school version.
You surely can use Dendro to thicken this look at tje various discussions
I solved it!
Was definitely the issue of the non-manifold edges.
Weaverbird thicken was enough to bake a closed mesh.
Thanks for your kind help :slight_smile:
