Minimum edge length (Min Edge) should serve this purpose but for some reason, it doesn’t restrict the minimum edge length. I can’t understand the reason and I have tried to alter other parameters but there is no success. How can I restrict the min edge length for mesh faces?
Thank you @pascal for your response! Does it mean that the Rhino meshing process primarily places mesh vertices into the ends of the joined edges and surface knot lines and only afterward takes into consideration other custom meshing settings?
Hi Vitalii - certainly on ends of edges there will always be a vertex, as for knot lines, I am not sure, myself, if those always get a vertex, but I would not be surprised.
