Criteria for checking for extremely short edges in a mesh
@stevebaer , @Gijs , @wim ,
I have a mesh which I imported using a Python/C++ script. I checked the mesh for extremely short edges. The criteria I am using is:
Extremely short edge is < 5 x max_range/10^7.22 = 0.000070 where max_range in X,Y,Z for my mesh = 231.7099 m.
My check reports 24 extremely short edges but Rhino’s Mesh Wizard reports 19.
What criteria is Rhino using? It seems to be different from what I found by looking in various Rhino documents.
My other checks all match Rhino:
Number of naked edges
Number of non-manifold edges
Number of duplicate faces & vertices
Number of degenerate faces
Number of intersecting faces (this was fun to code and get right)
Number of disjoint meshes
Number of faces & vertices
Faces with very small area
The only outstanding issue is extremely short edges.
I wrote my code because importing my large meshes (16M - 100M faces) and checking them was taking so long, up to 22 minutes. Now I can import and check the largest in just 25 sec (yes this includes checking for the intersection of 100,000,000 faces which is 10^16 compares before optimization). This is about 50X faster than the Mesh Wizard.
My script has made working with Rhino much more fun. Once I get everything working properly and fully documented, I will post it for your review. Perhaps you will find some easy ways to speed up the Mesh Wizard checking 10X to 50X times.
But for now I would really like to get the criteria Rhino is using for checking extremely short edges so that I can match the Mesh Wizard checking results in order to create good meshes that Rhino likes.
Regards,
Terry.
Look at rhinoSdkMesh.h in our C++ SDK. There is a class in there called RhinoCheckMeshOutput. I can see some of the lines in that class read
  // If m_bCheckForExtremelyShortEdges is true then the function will look for topological edges where the distance between the endpoints is less than m_DistanceToCheck.
  // m_totalExtremelyShortEdgeCt will contain the total extremely short edge count for all meshes.
  bool m_bCheckForExtremelyShortEdges; // Default is true.
  double m_DistanceToCheck; // Default is 1.0e-12
  int m_totalExtremelyShortEdgeCt;
