Hello folks,
I have an issue that I could not solve even after some hours googleing. My objective I think is rather simple but I am not able to create what I want, maybe some of you can help.
What I want to achieve:
I have an excel list with rooms, their names and the surface area. I want to translate that into surfaces visible in Rhino - ideally with their name an the surface area written on the surface.
I am able to create a surface in GH with the rectangle component and using the square root of each room’s desired square meters as input. I find it not ideal, however, to copy that for each room. Is there a possibility to have as an input a list maybe containing the square meters and then plugging that into the square roots → rectangle component and then having all the surfaces in one go?
Thank you very much
