When I use Properties-Texturemapping-Apply Box Mapping, There are some errors…
After I apllied texture to box(closed extrusion), I can’t edit anything… size, rotation etc…
But what I can’t understand is… If I make a new box and check… It works well…
What should I do…??
andy
(Andrew le Bihan)
June 22, 2014, 7:11am
2
What error messages are you seeing?
There are no error messages and just I can’t see the change in modeling texture…
and also i can’t change the texture’s size, direction etc…
The only way I can change the texture is to define ‘repeat’ in v-ray material editor…
andy
(Andrew le Bihan)
June 22, 2014, 7:35am
6
Do you see the correct mapping in rendered viewport display mode?
Yes, I can see the texture in rendered viewport… But not adjusted texture. normal texture…and I uploaded the file in here (http://rhinos.co.kr/korean/zb_rhinos/zboard.php?id=qa_ren&page=1&sn1=&divpage=1&sn=off&ss=on&sc=on&select_arrange=headnum&desc=asc&no=1214 ). test.3dm. Thanks!
andy
(Andrew le Bihan)
June 30, 2014, 8:13am
8
Sorry - just got back from a week’s holiday. I’m getting box mapping on that object just fine in that model.
:_ Andy
