Hi
V5,
I have inadvertently clicked on the name bar atop name column in layers, so now everything is in alphabetical order, I need to return it to how it was before doing that. How is this done ? I have never saved its state etc, as I am forever adding layers so any save would be well out of date.
You can turn off column sort, and it won’t happen again. Layers panel > Hammer icon > uncheck Column Sort
@pascal, maybe this could be default for V6? Until there is an undo for sorting, I think it should default to off. Can’t speak for everyone, but I never need or want to sort by any column.
Hi, Fortunately I was only a few minutes into the project, so exited without saving, and started over, it gave me the layer palette I had been using.
I would however heartily back up what gregb has just suggested.
It would have been impractical to rearrange a few hundred layers on some of my projects. Scary territory to have that so easily happen. Could cause major time loss. No undo for it either.
