How does one undo the name order in layer palette?
Hi, V5
I happened to click the name bar when aiming for the default layer, but edit undo has as last entry a command and my layer names are all scrambled (Aphabetical order yes but not where I need them) and I can’t see a way of undoing layer name order.
This in a project of 20 or so layers us bad enough, but if it was to happen in my large projects…disaster.
yes it pays to save LayerStateManager, but dont we all get carried away and whilst hitting ctrl S every so often, forget to save the layer palette using layerStateManager in the same way, as we dont intend to alter the palette, not even thinking to save it as one might do a ctrl s, as a matter of course, every hour or so…
Steve
Hi Steve -
In Rhino 5, you don’t. In later versions, you hit Undo.
In that case, make sure to uncheck the “Column Sort” option under the hammer icon.
Column sort now unticked.
Thanks.
Steve
