How can I make this pattern?
Hi guys, I accacidently saw this pattern today and I tried to make it with voronoi but failed. So does anyone know how to make it?
pattern.gh (9.5 KB)
The thing is, what I did with voronoi really doesn’t look like the picture. So maybe it was made with another solution?
Looks like your cells just need more size variation.
pattern.gh (23.0 KB)
Hi guys, I made a similar one, but not exactly the same. I post it to give anyone who is interested some inspiration.
Here is a way
take you curves (lines), split them in n segments with a length ratio defined
1 to 2 here
The use the line to draw an ellipsoid (length in X depending on length of segment), width and height defined by a slider.
Play with sliders
20210708_pattern_v2.gh (17.6 KB)
Thanks Laurent! I guess this is the right sulotion.
There is hardly ever a single “right solution”.
Haha yes yes, I should say “one of the best solutions”. :stuck_out_tongue_closed_eyes:
I never use Patch because it’s often not precise enough, but I played with the ‘S’ and ‘F’ input values to get results that Brep Join into a single polysurface, adapted from your code. A bit slow…
pattern_2021_Jul8a.gh (14.5 KB)
I’ve seen scalloped surfaces like this done differently but can’t remember how. Maybe Kangaroo?
I took the liberty of simplifying your code while increasing the random placement of the points, as suggested by @ftzuk.
pattern_2021_Jul8b.gh (16.8 KB)
Here is one from @DanielPiker:
great way but is there a way to turn this into a chiseled wooden carved surface like this ? thank you !:
Hello
did you look at this discussion ? If yes what is not good ? If no, please read it.
Lol your answer look like code ^^
