In the Autocad have .x, .y, .xy , etc , and than pick point. How can do it in rhino, thank you!
Hi -
I don’t have Auticad but Rhino has .x, .y, .xy, etc. filters. Are the different in any way?
- Select your object
- Start the Move command
- Pick point A
- type “.xy” in the command line
- Pick point A again
- type 0,0,0 and Enter at the command line or click on any point that is at Z0
It will use the XY coordinates of point A with the Z coordinates of what you typed or clicked
(it’s pretty cumbersome though)
- Pick point A
- type 0 ← z-level value
In the Autocad worked, but not worked on the rhino
Yes, seems to be a limitation of this particular function. You have to type all three coordinates 0,0,0 - typing 0 doesn’t work.
if I type 0,0,0, then point A move to 0,0,0, not .xy , z0 …
No, it moves to x,y,0 (assuming you followed the procedure exactly)
Why I type it v5, v6, v7, there aren’t work on all ? ![]()
ok, worked ! many thanks you!
This problem has bothered me for years ![]()
FWIW, in your specific case:
- Select the objects
- Run
Move - Type
vfor vertical - Snap to A
- Type
0
I was going to post this as well, but I forgot…
For this stuff I mostly use scripts.
I also use script many years, but I want to know that, why not? ![]()
