Hi guys, here’s my turn.
Sadly the Booleans, crucial task in my workflow, performed worse than on my 4yo i7-6700K backup rig.
Below the results with AA.
Holomark 2 R6 v2,61
Total Score: 315762
Total Runtime: 1508.78 sec
GPU scores: 297660
GPU_01 - 186.00 fps - Cube 4 tests
GPU_02 - 79.40 fps - UDT Shape
GPU_03 - 1111.10 fps - Wireframe
GPU_04 - 769.20 fps - Shaded
GPU_05 - 204.10 fps - Rendered
GPU_06 - 188.70 fps - Block Rendered
GPU_07 - 1202 units Nurbs @ 5 fps in Wireframe
GPU_08 - 498 units Nurbs @ 5 fps in Shaded
GPU_09 - 139 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 333.30 fps - RenderMesh Render
GPU_11 - 769.20 fps - RenderMesh RenderSpeed
GPU_12 - 769.20 fps - JoinedMesh Render
GPU_13 - 1666.70 fps - JoinedMesh RenderSpeed
GPU_14 - 206 units mesh @ 15 fps in Shaded
GPU_15 - 421 units mesh @ 15 fps in Render
GPU_16 - 1615 units mesh @ 15 fps in RenderSpeed
GPU_17 - 333.30 fps - mesh in Rendered Studio
GPU_18 - 64.50 fps - Nurbs in Rendered Studio
GPU_19 - 68.00 fps - Block Illustration
GPU_20 - 216.90 fps - 2D single
GPU_21 - 133.20 fps - 2D massive (20x)
CPU scores: 18102
CPU_01 - 6.41 sec - Booleans and Contours
CPU_02 - 1.23 sec - Twist and Taper (UDT)
CPU_03 - 6.51 sec - Meshing Mini
CPU_04 - 0.02 sec - Extract Render Mesh
CPU_05 - 0.03 sec - Join Render Mesh
CPU_06 - 9.47 sec - Reduce Mesh
CPU_07 - 0.82 sec - Calculating Technical display
CPU_08 - 3.13 sec - Making Silhouettes
System manufacturer
System Product Name
NVIDIA GeForce RTX 2080 SUPER - 4095.0 MB
DriverVersion: 26.21.14.4141
AMD Ryzen 9 3900X 12-Core Processor
NumberOfCores: 12 NumberOfLogicalProcessors: 24
MaxClockSpeed: 4.12 GHz
TotalPhysicalMemory: 16.0 GB
Microsoft Windows 10 Pro
Rhino 6 sr 20 64 bit
AA level = 4
And here without AA.
Holomark 2 R6 v2,61
Total Score: 331054
Total Runtime: 1517.6 sec
GPU scores: 310230
GPU_01 - 888.90 fps - Cube 4 tests
GPU_02 - 78.70 fps - UDT Shape
GPU_04 - 909.10 fps - Shaded
GPU_05 - 212.80 fps - Rendered
GPU_06 - 192.30 fps - Block Rendered
GPU_07 - 1211 units Nurbs @ 5 fps in Wireframe
GPU_08 - 503 units Nurbs @ 5 fps in Shaded
GPU_09 - 140 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 357.10 fps - RenderMesh Render
GPU_11 - 909.10 fps - RenderMesh RenderSpeed
GPU_14 - 296 units mesh @ 15 fps in Shaded
GPU_15 - 415 units mesh @ 15 fps in Render
GPU_16 - 1597 units mesh @ 15 fps in RenderSpeed
GPU_17 - 277.80 fps - mesh in Rendered Studio
GPU_18 - 64.10 fps - Nurbs in Rendered Studio
GPU_19 - 69.00 fps - Block Illustration
GPU_20 - 226.80 fps - 2D single
GPU_21 - 135.00 fps - 2D massive (20x)
CPU scores: 20824
CPU_01 - 6.43 sec - Booleans and Contours
CPU_02 - 1.19 sec - Twist and Taper (UDT)
CPU_03 - 3.02 sec - Meshing Mini
CPU_05 - 0.02 sec - Join Render Mesh
CPU_06 - 9.40 sec - Reduce Mesh
CPU_07 - 0.81 sec - Calculating Technical display
CPU_08 - 3.12 sec - Making Silhouettes
System manufacturer
System Product Name
AA level = None
