Holomark2_R6
Anyone any ideas why the Holomark2 just stops and shows no scores at the end?
Here is my command history of Holomark2_R
Command: HoloMark2_R6
Preparing Holomark 2 R6 v2,61
Rhino 6 sr 34 64 bit
Starting Holomark2
Rhino's language is English
1,  C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HoloMark2_Mini_black.3dm
HoloMark2_Mini_black.3dm was located
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HM2_V6_Wire.ini
HM2_V6_Wire.ini was located
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HM2_V6_Shaded.ini
HM2_V6_Shaded.ini was located
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HM2_V6_Render.ini
HM2_V6_Render.ini was located
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HM2_V6_Illustration.ini
HM2_V6_Illustration.ini was located
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HM2_V6_RenderSpeed.ini
HM2_V6_RenderSpeed.ini was located
All is ok
Command
Command
Command
Time to regen viewport 10 times = 0.00 seconds. (0.00 FPS)
Command
Command
HM2_V6_Wire  is installed!
Command
HM2_V6_Shaded  is installed!
Command
HM2_V6_Render  is installed!
Command
HM2_V6_Illustration  is installed!
Command
HM2_V6_RenderSpeed  is installed!
Creating meshes... Press Esc to cancel
GPU_01 Cube 4 tests took :6.56 sec @ 655.7 fps.
Command
Command
Command
Time to regen viewport 10 times = 0.02 seconds. (625.00 FPS)
Calculating Contours... Press Esc to cancel
CPU_01 Booleans and Contours took :5.44 sec
CPU_02 UDT Shape took :0.97 sec
GPU_02 Test took :1.22 sec @ 82.0 fps.
Command
Command
Command
Time to regen viewport 10 times = 0.01 seconds. (666.67 FPS)
Command: -_Import
Name of the file to import ( Browse ): "C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\\HoloMark2_Mini_black.3dm"
Import scaling: Keep <ModelSize> ( DimensionNumbers ): _Enter
Successfully read file "C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\\HoloMark2_Mini_black.3dm"
Command: _Enter
Can not close the last viewport
Command
CPU_03 Meshing Rhino took :2.66 sec
GPU_03 Test took :0.14 sec @ 714.3 fps.
GPU_04 Test took :0.19 sec @ 526.3 fps.
GPU_05 Test took :0.69 sec @ 144.9 fps.
Mini converted to block
GPU_06 Test took :0.72 sec @ 138.9 fps.
Your system handled 511 units before dropping below 5 fps
Your system handled 289 units before dropping below 5 fps
Your system handled 124 units before dropping below 5 fps
CPU_04 ExtractRendermesh took :0.02 sec
GPU_10 Test took :0.45 sec @ 222.2 fps.
GPU_11 Test took :0.17 sec @ 588.2 fps.
CPU_05 Joining meshes took :0.02 sec
MiniMesh converted to block
GPU_12 Test took :0.19 sec @ 526.3 fps.
GPU_13 Test took :0.11 sec @ 909.1 fps.
Your system handled 71 units before dropping below 15 fps
Your system handled 202 units before dropping below 15 fps
Command: _CommandHistory
Hi there,
just ran holomark 2.61 on my new PC with quite a low result.
Even my laptop with its 8700K and gtx1070 had better results.
Anyone an idea what’s wrong with the system?
Holomark 2 R6 v2,61
Total Score: 146560
Total Runtime: 4302.81 sec
GPU scores: 133860
GPU_01 - 64.10 fps - Cube 4 tests
GPU_02 - 43.10 fps - UDT Shape
GPU_03 - 454.50 fps - Wireframe
GPU_04 - 294.10 fps - Shaded
GPU_05 - 69.40 fps - Rendered
GPU_06 - 59.20 fps - Block Rendered
GPU_07 - 455 units Nurbs @ 5 fps in Wireframe
GPU_08 - 105 units Nurbs @ 5 fps in Shaded
GPU_09 - 32 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 98.00 fps - RenderMesh Render
GPU_11 - 256.40 fps - RenderMesh RenderSpeed
GPU_12 - 227.30 fps - JoinedMesh Render
GPU_13 - 454.50 fps - JoinedMesh RenderSpeed
GPU_14 - 107 units mesh @ 15 fps in Shaded
GPU_15 - 615 units mesh @ 15 fps in Render
GPU_16 - 1824 units mesh @ 15 fps in RenderSpeed
GPU_17 - 88.50 fps - mesh in Rendered Studio
GPU_18 - 18.30 fps - Nurbs in Rendered Studio
GPU_19 - 42.90 fps - Block Illustration
GPU_20 - 144.70 fps - 2D single
GPU_21 - 59.10 fps - 2D massive (20x)
CPU scores: 12700
CPU_01 - 8.72 sec - Booleans and Contours
CPU_02 - 2.27 sec - Twist and Taper (UDT)
CPU_03 - 12.35 sec - Meshing Mini
CPU_04 - 0.12 sec - Extract Render Mesh
CPU_05 - 0.04 sec - Join Render Mesh
CPU_06 - 10.78 sec - Reduce Mesh
CPU_07 - 1.29 sec - Calculating Technical display
CPU_08 - 3.80 sec - Making Silhouettes
Micro-Star International Co., Ltd.
MS-7C37
AMD Radeon RX 6800 - 4095.0 MB
DriverVersion: 27.20.14535.3005
AMD Ryzen 7 5800X 8-Core Processor
NumberOfCores: 8 NumberOfLogicalProcessors: 16
MaxClockSpeed: 3.8 GHz
TotalPhysicalMemory: 16.0 GB
Microsoft Windows 10 Pro
  • None - 64-Bit
Rhino 7 sr 5 64 bit
AA level = 4
Hi @Holo ,
where can I download latest release to test with Rhino 7?
I just installed ā€œHolomark2_R6_2ā€ from post 2 but I get an error
Thanks!
It installed fine on R7 but it just stops where you have multiple minis being copied. The first time it stopped at 4 minis and GPU test 4 and when I ran it again it stopped at 4 minis and GPU test 6.
RTX 3060, B550i, 32GB RAM @3600, Ryzen 5800x (latest release on all software/OS).
5950x and 3090 system for reference:
Holomark 2 R6 v2,61
Total Score: 425026
Total Runtime: 2239.51 sec
GPU scores: 405380
GPU_01 - 221.00 fps - Cube 4 tests
GPU_02 - 105.30 fps - UDT Shape
GPU_03 - 909.10 fps - Wireframe
GPU_04 - 714.30 fps - Shaded
GPU_05 - 263.20 fps - Rendered
GPU_06 - 243.90 fps - Block Rendered
GPU_07 - 1831 units Nurbs @ 5 fps in Wireframe
GPU_08 - 640 units Nurbs @ 5 fps in Shaded
GPU_09 - 156 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 454.50 fps - RenderMesh Render
GPU_11 - 769.20 fps - RenderMesh RenderSpeed
GPU_12 - 909.10 fps - JoinedMesh Render
GPU_13 - 1250.00 fps - JoinedMesh RenderSpeed
GPU_14 - 236 units mesh @ 15 fps in Shaded
GPU_15 - 713 units mesh @ 15 fps in Render
GPU_16 - 2743 units mesh @ 15 fps in RenderSpeed
GPU_17 - 434.80 fps - mesh in Rendered Studio
GPU_18 - 73.50 fps - Nurbs in Rendered Studio
GPU_19 - 95.20 fps - Block Illustration
GPU_20 - 284.90 fps - 2D single
GPU_21 - 156.00 fps - 2D massive (20x)
CPU scores: 19646
CPU_01 - 4.72 sec - Booleans and Contours
CPU_02 - 1.12 sec - Twist and Taper (UDT)
CPU_03 - 7.94 sec - Meshing Mini
CPU_04 - 0.02 sec - Extract Render Mesh
CPU_05 - 0.02 sec - Join Render Mesh
CPU_06 - 8.67 sec - Reduce Mesh
CPU_07 - 0.77 sec - Calculating Technical display
CPU_08 - 2.19 sec - Making Silhouettes
ASUS
System Product Name
NVIDIA GeForce RTX 3090 - 4095.0 MB
DriverVersion: 30.0.14.7111
AMD Ryzen 9 5950X 16-Core Processor
NumberOfCores: 16 NumberOfLogicalProcessors: 32
MaxClockSpeed: 3.4 GHz
TotalPhysicalMemory: 64.0 GB
  • None - 64-bit
AA level = 4
It happens to me on RH7 too, I think it needs to be worked on, It works on another machine
Nvidia A40 + Ryzen 5950x
Holomark 2 R6 v2,61
Total Score: 460682
Total Runtime: 2206.59 sec
GPU scores: 436930
GPU_01 - 869.60 fps - Cube 4 tests
GPU_02 - 109.90 fps - UDT Shape
GPU_03 - 1250.00 fps - Wireframe
GPU_04 - 1250.00 fps - Shaded
GPU_05 - 277.80 fps - Rendered
GPU_06 - 227.30 fps - Block Rendered
GPU_07 - 1770 units Nurbs @ 5 fps in Wireframe
GPU_08 - 662 units Nurbs @ 5 fps in Shaded
GPU_09 - 170 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 500.00 fps - RenderMesh Render
GPU_11 - 1250.00 fps - RenderMesh RenderSpeed
GPU_12 - 1111.10 fps - JoinedMesh Render
GPU_13 - 2000.00 fps - JoinedMesh RenderSpeed
GPU_14 - 229 units mesh @ 15 fps in Shaded
GPU_15 - 873 units mesh @ 15 fps in Render
GPU_16 - 2760 units mesh @ 15 fps in RenderSpeed
GPU_17 - 526.30 fps - mesh in Rendered Studio
GPU_18 - 78.70 fps - Nurbs in Rendered Studio
GPU_19 - 102.00 fps - Block Illustration
GPU_20 - 255.80 fps - 2D single
GPU_21 - 140.60 fps - 2D massive (20x)
CPU scores: 23752
CPU_01 - 4.80 sec - Booleans and Contours
CPU_02 - 1.03 sec - Twist and Taper (UDT)
CPU_03 - 2.44 sec - Meshing Mini
CPU_05 - 0.01 sec - Join Render Mesh
CPU_06 - 9.73 sec - Reduce Mesh
CPU_07 - 0.83 sec - Calculating Technical display
ASUS
System Product Name
NVIDIA Tesla V100-PCIE-16GB - 0.0 MB
DriverVersion: 30.0.14.7168
NVIDIA A40 - 4095.0 MB
TotalPhysicalMemory: 128.0 GB
Microsoft Windows 11 Pro
  • None - 64-bit
Rhino 6 sr 35 64 bit
AA level = 4
Holy crap! Nice job!
-J
just benchmarked my system with Ryzen 5800X CPU and Radeon RX6800.
Seems these are not really top of the line results…
Actually your CPU score is the highest I’ve ever seen beating 59xx and the threadrippers.
Also if you run Holomark on RH6 you will get substantially higher results.
I think my machine isn’t good Enough :pleading_face:
Total Score: 246939
Total Runtime: 976.45 sec
GPU scores: 224140
GPU_01 - 1052.60 fps - Cube 4 tests
GPU_02 - 70.90 fps - UDT Shape
GPU_03 - 1111.10 fps - Wireframe
GPU_04 - 769.20 fps - Shaded
GPU_05 - 142.90 fps - Rendered
GPU_06 - 138.90 fps - Block Rendered
GPU_07 - 934 units Nurbs @ 5 fps in Wireframe
GPU_08 - 259 units Nurbs @ 5 fps in Shaded
GPU_09 - 79 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 263.20 fps - RenderMesh Render
GPU_11 - 625.00 fps - RenderMesh RenderSpeed
GPU_14 - 157 units mesh @ 15 fps in Shaded
GPU_15 - 306 units mesh @ 15 fps in Render
GPU_16 - 973 units mesh @ 15 fps in RenderSpeed
GPU_17 - 322.60 fps - mesh in Rendered Studio
GPU_18 - 36.50 fps - Nurbs in Rendered Studio
GPU_19 - 69.00 fps - Block Illustration
GPU_20 - 50.70 fps - 2D single
GPU_21 - 10.40 fps - 2D massive (20x)
CPU scores: 22799
CPU_01 - 4.03 sec - Booleans and Contours
CPU_02 - 1.16 sec - Twist and Taper (UDT)
CPU_03 - 2.36 sec - Meshing Mini
CPU_04 - 0.07 sec - Extract Render Mesh
CPU_06 - 11.00 sec - Reduce Mesh
CPU_07 - 0.76 sec - Calculating Technical display
CPU_08 - 2.53 sec - Making Silhouettes
LENOVO
82JQ
NVIDIA GeForce RTX 3070 Laptop GPU - 4095.0 MB
AMD Ryzen 7 5800H with Radeon Graphics
MaxClockSpeed: 3.2 GHz
Microsoft Windows 10 Home
  • None - 64-bit
Rhino 7 sr 9 64 bit
AA level = 4
Try Running it on Rhino 6 and your score will exceed 350,000. also if you have V-Ray installed, disable it.
So the GPU is not that important for performance in Rhino?
I just wondered why others have reached far better overall scores. Didn’t attention the CPU score.
Thanks…
I’ll try it
@BauerNaval GPU is helpful for the viewport moment and the more complex the model the more powerful GPU you’ll need
Your GPU is top of the Line, just try running it on RH6 and you will likely see 350,000 to 450,000
I’m sure there’ll be a better version of HoloMark for Rhino 7 and later when @Holo gets around to put the finishing touches on it (:
I’ve run Holomark on R6, just Section Tools installed, no Vray or anything else.
But the score is just litle higher than on R7. Graphics driver was just updated this morning, think I will search for an professionel version instead of the gaming driver and retry.
Edit: My Monitor is an Dell 49" Ultra Wide with resolution 5120x1440.
That might make a difference compared to normal 28" or 30 " monitors.
Holomark 2 R6 v2,61
Total Score: 304563
Total Runtime: 1552.51 sec
GPU scores: 276970
GPU_01 - 727.30 fps - Cube 4 tests
GPU_02 - 93.50 fps - UDT Shape
GPU_03 - 769.20 fps - Wireframe
GPU_04 - 500.00 fps - Shaded
GPU_05 - 100.00 fps - Rendered
GPU_06 - 100.00 fps - Block Rendered
GPU_07 - 1277 units Nurbs @ 5 fps in Wireframe
GPU_08 - 315 units Nurbs @ 5 fps in Shaded
GPU_09 - 76 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 158.70 fps - RenderMesh Render
GPU_11 - 416.70 fps - RenderMesh RenderSpeed
GPU_12 - 500.00 fps - JoinedMesh Render
GPU_13 - 1111.10 fps - JoinedMesh RenderSpeed
GPU_14 - 181 units mesh @ 15 fps in Shaded
GPU_15 - 935 units mesh @ 15 fps in Render
GPU_16 - 1846 units mesh @ 15 fps in RenderSpeed
GPU_17 - 151.50 fps - mesh in Rendered Studio
GPU_18 - 42.00 fps - Nurbs in Rendered Studio
GPU_19 - 62.90 fps - Block Illustration
GPU_20 - 237.50 fps - 2D single
GPU_21 - 123.30 fps - 2D massive (20x)
CPU scores: 27593
CPU_01 - 4.63 sec - Booleans and Contours
CPU_02 - 0.96 sec - Twist and Taper (UDT)
CPU_03 - 2.13 sec - Meshing Mini
CPU_06 - 7.53 sec - Reduce Mesh
CPU_07 - 0.66 sec - Calculating Technical display
CPU_08 - 2.18 sec - Making Silhouettes
MS-7C37
DriverVersion: 27.20.22001.14011
TotalPhysicalMemory: 80.0 GB
  • None - 64-Bit
AA level = 4
Although I’m not that familiar with AMD Cards, I can see the score is comparable to a 2080TI or RTX 3070. which is considered super high-end. maybe some driver update or some windows optimization can give you the extra performance for your hardware. for me the increase in memory frequency to 3200 mhz added to my GPU score. not sure why but seems working.
R6 score is a bit better ( I know I have a problem with my ram Timing,I’ll upgrade it later and check again )
holomark 2 R6 v2,61
Total Score: 263230
Total Runtime: 1101.31 sec
GPU scores: 247610
GPU_01 - 156.90 fps - Cube 4 tests
GPU_02 - 69.40 fps - UDT Shape
GPU_04 - 909.10 fps - Shaded
GPU_05 - 212.80 fps - Rendered
GPU_06 - 181.80 fps - Block Rendered
GPU_07 - 1149 units Nurbs @ 5 fps in Wireframe
GPU_08 - 438 units Nurbs @ 5 fps in Shaded
GPU_09 - 107 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 294.10 fps - RenderMesh Render
GPU_12 - 714.30 fps - JoinedMesh Render
GPU_14 - 163 units mesh @ 15 fps in Shaded
GPU_15 - 221 units mesh @ 15 fps in Render
GPU_16 - 360 units mesh @ 15 fps in RenderSpeed
GPU_17 - 303.00 fps - mesh in Rendered Studio
GPU_18 - 48.50 fps - Nurbs in Rendered Studio
GPU_19 - 57.10 fps - Block Illustration
GPU_20 - 163.70 fps - 2D single
GPU_21 - 92.50 fps - 2D massive (20x)
CPU scores: 15620
CPU_01 - 7.21 sec - Booleans and Contours
CPU_02 - 1.36 sec - Twist and Taper (UDT)
CPU_03 - 9.06 sec - Meshing Mini
CPU_04 - 0.03 sec - Extract Render Mesh
CPU_06 - 10.23 sec - Reduce Mesh
CPU_07 - 0.97 sec - Calculating Technical display
CPU_08 - 3.13 sec - Making Silhouettes
LENOVO
82JQ
  • None - 64-bit
AA level = 4
MM but it says I have NVIDIA GeForce RTX 3070 Laptop GPU - 4095.0 MB but the Gpu vram is 8Gb not 4
