Holomark scores V6 vs V5
How do I interpret the difference in scores between V5 and V6?
82222 for V6 and 27543 for V5. V5 seems to run so much better for me.
Thanks,
Dennis
Holomark 2 R6 v2,61
Total Score: 82222
Total Runtime: 401.28 sec
GPU scores: 71530
GPU_01 - 104.70 fps - Cube 4 tests
GPU_02 - 47.20 fps - UDT Shape
GPU_03 - 322.60 fps - Wireframe
GPU_04 - 227.30 fps - Shaded
GPU_05 - 76.90 fps - Rendered
GPU_06 - 86.20 fps - Block Rendered
GPU_07 - 246 units Nurbs @ 5 fps in Wireframe
GPU_08 - 151 units Nurbs @ 5 fps in Shaded
GPU_09 - 58 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 95.20 fps - RenderMesh Render
GPU_11 - 188.70 fps - RenderMesh RenderSpeed
GPU_12 - 212.80 fps - JoinedMesh Render
GPU_13 - 370.40 fps - JoinedMesh RenderSpeed
GPU_14 - 29 units mesh @ 15 fps in Shaded
GPU_15 - 69 units mesh @ 15 fps in Render
GPU_16 - 187 units mesh @ 15 fps in RenderSpeed
GPU_17 - 88.50 fps - mesh in Rendered Studio
GPU_18 - 31.90 fps - Nurbs in Rendered Studio
GPU_19 - 44.40 fps - Block Illustration
GPU_20 - 82.60 fps - 2D single
GPU_21 - 54.30 fps - 2D massive (20x)
CPU scores: 10692
CPU_01 - 8.85 sec - Booleans and Contours
CPU_02 - 1.87 sec - Twist and Taper (UDT)
CPU_03 - 11.02 sec - Meshing Mini
CPU_04 - 0.03 sec - Extract Render Mesh
CPU_05 - 0.04 sec - Join Render Mesh
CPU_06 - 18.86 sec - Reduce Mesh
CPU_07 - 1.39 sec - Calculating Technical display
CPU_08 - 4.70 sec - Making Silhouettes
Microsoft Corporation
Surface Book
NVIDIA GeForce GTX 965M - 2048.0 MB
DriverVersion: 23.21.13.9140
Intel® HD Graphics 520 - 1024.0 MB
DriverVersion: 24.20.100.6293
Intel® Core™ i7-6600U CPU @ 2.60GHz
NumberOfCores: 2 NumberOfLogicalProcessors: 4
MaxClockSpeed: 2.81 GHz
TotalPhysicalMemory: 16.0 GB
Microsoft Windows 10 Pro
  • None - 64-bit
Rhino 6 sr 14 64 bit
AA level = 8
Holomark 2 v2,2,03
Total Score: 27542
Total Runtime: 159.39 sec
GPU scores: 16030
GPU_01 - 408.20 fps - Cube 4 tests
GPU_02 - 33.80 fps - UDT Shape
GPU_03 - 66.70 fps - Wireframe
GPU_04 - 46.10 fps - Shaded
GPU_05 - 28.80 fps - Rendered
GPU_06 - 28.70 fps - Block Rendered
GPU_07 - 17 units Nurbs @ 5 fps in Wireframe
GPU_08 - 10 units Nurbs @ 5 fps in Shaded
GPU_09 - 24 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 98.00 fps - RenderMesh Render
GPU_11 - 84.00 fps - RenderMesh RenderSpeed
GPU_12 - 56.20 fps - JoinedMesh Render
GPU_13 - 67.60 fps - JoinedMesh RenderSpeed
GPU_14 - 1 units mesh @ 15 fps in Shaded
GPU_15 - 3 units mesh @ 15 fps in Render
GPU_16 - 7 units mesh @ 15 fps in RenderSpeed
GPU_17 - 72.50 fps - mesh in Rendered Studio
GPU_18 - 10.20 fps - Nurbs in Rendered Studio
GPU_19 - 22.90 fps - Block Illustration
GPU_20 - 42.20 fps - 2D single
GPU_21 - 5.60 fps - 2D massive (20x)
CPU scores: 11512
CPU_01 - 11.07 sec - Booleans and Contours
CPU_02 - 1.81 sec - Twist and Taper (UDT)
CPU_03 - 4.40 sec - Meshing Mini
CPU_04 - 0.04 sec - Extract Render Mesh
CPU_05 - 0.06 sec - Join Render Mesh
CPU_06 - 19.33 sec - Reduce Mesh
CPU_07 - 3.32 sec - Calculating Technical display
CPU_08 - 3.40 sec - Making Silhouettes
Surface Book
  • None - 64-bit
Rhino 5 sr 14 64 bit
What is the version of Rhino6 that you use?
I’m asking because I noticed a performance drop since I updated to 6.15
compared with 6.13.
reported here:
Some days ago I tried opening a simple demo file in V5 and V6eval.
It is a very simple Box with Textures resembling a simplified building with a sunshade system to show clients how that shadingsystem works. All rendered mode with shadows.
V6 opened very laggy, nearly nonresponsive.
V5 was fast.
Testmaxspeed v5:6 seconds
Testmaxspeed V6: 1. Run 100seconds. 2.run 60 secknds.
DELlL M6700, Quadro K3000M, Drivers are up to date. Also tried the driver. that is recommended by Dell. No difference.
The File was made in V5 some time ago.
run the command SystemInfo in Rhino6
and copy/paste the result here
Hello - make sure rendered the Skylight setting is the same in both -
Ok, thanks I"ll try on Tuesday, when back from the boat…Notebookfree Area here…just can say it was the exact same File, V6R15 fresh installed, nothing modified…
