New Ryzen build with stock CPU/memory settings/cooler. Will switch to AIO cooler and OC sometime soon.
Holomark 2 R6 v2,61
Total Score: 302798
Total Runtime: 1402.29 sec
GPU scores: 284980
GPU_01 - 217.40 fps - Cube 4 tests
GPU_02 - 84.00 fps - UDT Shape
GPU_03 - 909.10 fps - Wireframe
GPU_04 - 769.20 fps - Shaded
GPU_05 - 204.10 fps - Rendered
GPU_06 - 188.70 fps - Block Rendered
GPU_07 - 1137 units Nurbs @ 5 fps in Wireframe
GPU_08 - 514 units Nurbs @ 5 fps in Shaded
GPU_09 - 154 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 357.10 fps - RenderMesh Render
GPU_11 - 1111.10 fps - RenderMesh RenderSpeed
GPU_12 - 769.20 fps - JoinedMesh Render
GPU_13 - 1666.70 fps - JoinedMesh RenderSpeed
GPU_14 - 179 units mesh @ 15 fps in Shaded
GPU_15 - 381 units mesh @ 15 fps in Render
GPU_16 - 1146 units mesh @ 15 fps in RenderSpeed
GPU_17 - 370.40 fps - mesh in Rendered Studio
GPU_18 - 69.00 fps - Nurbs in Rendered Studio
GPU_19 - 50.50 fps - Block Illustration
GPU_20 - 163.70 fps - 2D single
GPU_21 - 106.30 fps - 2D massive (20x)
CPU scores: 17818
CPU_01 - 6.04 sec - Booleans and Contours
CPU_02 - 1.33 sec - Twist and Taper (UDT)
CPU_03 - 7.29 sec - Meshing Mini
CPU_04 - 0.02 sec - Extract Render Mesh
CPU_05 - 0.02 sec - Join Render Mesh
CPU_06 - 9.74 sec - Reduce Mesh
CPU_07 - 0.80 sec - Calculating Technical display
CPU_08 - 2.82 sec - Making Silhouettes
Gigabyte Technology Co., Ltd.
X570 AORUS ELITE
NVIDIA TITAN Xp COLLECTORS EDITION - 4095.0 MB
DriverVersion: 26.21.14.3186
AMD Ryzen 7 3800X 8-Core Processor
NumberOfCores: 8 NumberOfLogicalProcessors: 16
MaxClockSpeed: 3.89 GHz
TotalPhysicalMemory: 32.0 GB
Microsoft Windows 10 Pro
- None - 64-bit
Rhino 6 sr 20 64 bit
AA level = 4
