Hello All, and @Holo
I clearly notice an inferior viewport performance on Rhino 7 compared to Rhino 6, especially in shaded mode
just randomly benchmarking my rig with Windows 11.
Same Machine, Same OS and without restarting.
Comparision.pdf (42.7 KB)
Holomark 2 R6 v2,61
Rhino 6 - Total Score: 212753
Total Runtime: 715.63 sec
GPU scores: 198030
GPU_01 - 579.70 fps - Cube 4 tests
GPU_02 - 69.00 fps - UDT Shape
GPU_03 - 769.20 fps - Wireframe
GPU_04 - 625.00 fps - Shaded
GPU_05 - 151.50 fps - Rendered
GPU_06 - 133.30 fps - Block Rendered
GPU_07 - 655 units Nurbs @ 5 fps in Wireframe
GPU_08 - 448 units Nurbs @ 5 fps in Shaded
GPU_09 - 97 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 222.20 fps - RenderMesh Render
GPU_11 - 625.00 fps - RenderMesh RenderSpeed
GPU_12 - 526.30 fps - JoinedMesh Render
GPU_13 - 1111.10 fps - JoinedMesh RenderSpeed
GPU_14 - 115 units mesh @ 15 fps in Shaded
GPU_15 - 347 units mesh @ 15 fps in Render
GPU_16 - 750 units mesh @ 15 fps in RenderSpeed
GPU_17 - 256.40 fps - mesh in Rendered Studio
GPU_18 - 51.50 fps - Nurbs in Rendered Studio
GPU_19 - 59.20 fps - Block Illustration
GPU_20 - 121.80 fps - 2D single
GPU_21 - 78.70 fps - 2D massive (20x)
CPU scores: 14723
CPU_01 - 6.87 sec - Booleans and Contours
CPU_02 - 1.36 sec - Twist and Taper (UDT)
CPU_03 - 3.65 sec - Meshing Mini
CPU_04 - 0.03 sec - Extract Render Mesh
CPU_05 - 0.02 sec - Join Render Mesh
CPU_06 - 17.58 sec - Reduce Mesh
CPU_07 - 1.28 sec - Calculating Technical display
CPU_08 - 3.17 sec - Making Silhouettes
EVGA INTERNATIONAL CO.,LTD
To be filled by O.E.M.
NVIDIA Quadro RTX 4000 - 4095.0 MB
DriverVersion: 30.0.14.7111
NVIDIA Tesla V100-PCIE-16GB - ERROR AdapterRAM
Intel(R) Core™ i7-4790K CPU @ 4.00GHz
NumberOfCores: 4 NumberOfLogicalProcessors: 8
MaxClockSpeed: 4.0 GHz
TotalPhysicalMemory: 32.0 GB
Microsoft Windows 11 Pro
- None - 64-bit
Rhino 6 sr 34 64 bit
AA level = 8
Holomark 2 R6 v2,61
Holomark 2 R6 v2,61
Rhino 7 Total Score: 198333
Total Runtime: 741.22 sec
GPU scores: 183080
GPU_01 - 615.40 fps - Cube 4 tests
GPU_02 - 55.60 fps - UDT Shape
GPU_03 - 1111.10 fps - Wireframe
GPU_05 - 120.50 fps - Rendered
GPU_06 - 106.40 fps - Block Rendered
GPU_07 - 764 units Nurbs @ 5 fps in Wireframe
GPU_08 - 209 units Nurbs @ 5 fps in Shaded
GPU_09 - 64 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 227.30 fps - RenderMesh Render
GPU_11 - 588.20 fps - RenderMesh RenderSpeed
GPU_12 - 769.20 fps - JoinedMesh Render
GPU_13 - 1250.00 fps - JoinedMesh RenderSpeed
GPU_14 - 100 units mesh @ 15 fps in Shaded
GPU_15 - 336 units mesh @ 15 fps in Render
GPU_16 - 584 units mesh @ 15 fps in RenderSpeed
GPU_17 - 277.80 fps - mesh in Rendered Studio
GPU_18 - 30.80 fps - Nurbs in Rendered Studio
GPU_19 - 56.50 fps - Block Illustration
GPU_20 - 55.80 fps - 2D single
GPU_21 - 8.60 fps - 2D massive (20x)
CPU scores: 15253
CPU_01 - 5.42 sec - Booleans and Contours
CPU_02 - 1.72 sec - Twist and Taper (UDT)
CPU_03 - 3.72 sec - Meshing Mini
CPU_04 - 0.08 sec - Extract Render Mesh
CPU_05 - 0.03 sec - Join Render Mesh
CPU_06 - 17.32 sec - Reduce Mesh
CPU_07 - 1.29 sec - Calculating Technical display
CPU_08 - 3.20 sec - Making Silhouettes
- None - 64-bit
Rhino 7 sr 8 64 bit
AA level = 8
This is as likely as having decreased performance build in due to feature development and bug fixing…
