Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 2-9-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.55
- Secondary monitor attached to adapter port #2
Secondary graphics devices.
Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 10-28-2020 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-9-2021
Driver Version: 27.21.14.6155
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
Ref comparison on Rhino 6. Was on the same machine, at the same time (no other software open) and the entire file components copied and pasted into new files opened in both v6 & v7. Also tested after system reboot - same result each time.
Also tested on another similar machine in the office running another license of v7 - same.
There have been periodic reports of this slowness and some fixes have been applied, but there still seem to be people who are experiencing this.
I guess a couple of things to try to narrow down the cause -
Temporarily disable SimLab and SectionTools plug-ins
Try the selection/show/hide with the Properties panel closed
Try with some individual object types to see if it is one or the other that might be causing the slowdown
Thank you for the suggestions. Results as follows:
Simlab & Sectiontools off - no change
As per 1 with layer tab, rather then properties tab, active - no change
As per 1 with properties panel closed - no change
Tried show/hide with:
a) No points selected- no change
b) No curves - instant(ish)
c) No blocks - no change (maybe marginal but >2min)
d) No hatches - no change
d) Just curves selected - 1min
If hide not completed within 20 seconds then i hard stop it and re-open file…
So for now am running out of patience, and opting to work in v6 where same file runs quickly.
Anyone from McNeel want to look at the file and try figure it out?
I have a file here with 246 129 curves where hiding / showing parts of them takes around 5 seconds and it behaves the same way on Rhino 6 here. So, yes, please upload a file on Rhino - Upload to Support - you can use wim@mcneel.com in the recipient field and please paste the url to this Discourse thread in the comments field.
Do you have 3 screens connected to you machine? Does it make any difference if there’s only one screen?
Hello - there have been fixes in this area - you can try the 7.6 release candidate by changing the ‘Update frequency’ in Options > Updates and Statistics page to ‘Service release candidate’
Further fixes are in the 7.7 build which should become available next week as a release candidate.
SR7.6 show/hide working much quicker now. On a par or better than v6. Always appreciate the McNeel progress and Rhino updates.
Still experiencing significant lag between selecting an object and edit becoming available. I.e. text or dimension annotations and control points, or making fillet between curves etc. This works fin and quickly on small files, but very tedious on large files. Is there work in progress on this too?
