Hello
you could test ShapeMap, but I am not sure it is good here
or transform your Polysurface in a Surface
then look at this discussion
Dear community
I tried some plugins to put hexagons on a surface with a seam.
I tried lunchbox, ngon. I didn’t try Paneling tool. These tools have problems or the seams (lunchbox, or too much points (polyline with 9 points for ngon plugin), not hexagons at the ends, or too much distorsion …
As I need quite nice hexagons I developed a little tool 2 hours work).
You just have to put the number of hexagons on a ring and say where is the seam (U or V).
[image]
Did I miss an existing tool ?
M…
here my test with my tool
hexagon.gh (8.6 KB)
But if you want the whole object there will be no magic, or hexgons will become smaller on the center of disk or there will be distorsion on "skirt’ and you could apply this logic
Hi all!
I decided to write this post because I want help with something about “how-to-model”.
See the reference picture:
[replacement-2pcs-lot-wireless-microphone]
I found a solution using displacement maps but first, I tried some ways to model this in Rhino without luck.
Any ideas?
Thanks,
Luis
