Creating a circular, hexagonal fading pattern with paneling tools curve attractor
Hi guys,
I’m fairly new to the grasshopper game, most selftaught and therefore not really well founded. At this moment I need help since I have no clue whatsoever is going on with my definition. Here’s my description:
I am currently working on a geometry which requires to have a hexagonal pattern in a hexagonal grid, fading big to small from the outside edge to the inside edge inside of a loft surface. The picture below shows the direction, but is based on a surface domain grid, that is rectangular and not hexagonal.
Ideally the hexagons will be interlaced, resulting in a “blackout” area outside the loft, breaking up towards the middle. I managed to have the base curve moved to the each of the grid points, rotated them to the center but when I apply a curve attraction to it, it gives me something like this:
I’m guessing it hast something to do with tree management, which I’m poorly equipped with.
Also, the second I apply “convert to diamond grid”, something goes wrong.
I will include my working files to this so you can have a look.
Thank you so much in advance for any hint!!
Cheers,
Hendrik
definition.gh (7.5 KB) bezel.3dm (829.7 KB)
Have a try Lunchbox plugin.
definition_re.gh (24.5 KB)
Hi HS_Kim,
thanks a lot, that works good for me :slight_smile: I did not have the Lunchbox Plugin until today :astonished:
If you or anyone else can anyway explain to me why I was not able to achieve it with my original definition I would be so pleased! But otherwise, I call this job done :smile:
Thanks a lot!
I’m not sure how the Curve Attraction component works, but maybe Curve Closest Point (using the distance output) will give you the output I think you are looking for in your original definition.
Also FYI, the title HELP is a bit of a no no in this forum. See item 1.
I don’t use often Panelling tools but it makes a mess
The convert to diamond outputs nulls and the attractor component don’t output a value for these data !!!
A way to deal with this problem
definition.gh (10.0 KB)
Thank you, Adam! I will try the Curve Closest Point next :slight_smile: Sorry for the title, revised it!
Thank you Laurent! I will try to understand your part of the definition and incorporate it!
Hey guys,
just wanted to let you know that I did it! See photo below:
Curve Closest Point worked a lot better than Curve Attraction!
Thanks so much guys
Hendrik
Hi Hendrik,
Meine Hexagons drhen sich nicht mit der kurvenferlauf, hast Du den gh script immer noch?
MfG
Igor
