Help with Visual Issues
Has anyone found a way to make rhino with visual Arq plug in shop showing hidden lines in the viewport? It looks fine when doing an arial view but as soon as i go lower the line duplication starts being an issue.
This isn’t the only file i have this issue with.
Hi @Joshua_M_Eckert I’ve seen similar display issues in models that have geometry very far from the origin of coordinates, or geometry very far from one piece to another. Can you double-check that? or share the file so we can take a look?
