Hi , i am trying to make a wall conigurator for wood cladding panels , i have created some parametric panel , i need to create wall and divide surface like curtain grid in revit curtain wall command in revit and then define easch panel type is this possible using grasshopoer
Please show some reference pictures or files.
Greetings, to work with Revit there is a plugin called Rhino.Inside.Revit, to split a surface into fragments there is a node called Isotrim, sometimes it is more convenient to start with the wall plan rather than the profile in such a case you may need a plugin called Clipper. If you have more specific problems, please contact us again.
