How can I create a curtain wall panel in revit based on a rhino curved trimmed surfaces. It seems to that Ive tried every existing plugin for grasshopper and revit and still havent found way to get it done. Id appreciate your help if you know how to do it please help me. in the link below you can see the example of the bent trimmed surface I am speaking about.
Hi Shamil,
Here is an example on how you can do it with GeometryGym.
You can download the plug-ins from here:
You will need RhinoIFC and RevitIFC plug-ins. Bake to IFC then import into Revit.
OR
if you have Rhino Inside Revit working you can now bake directly from grasshopper into Revit using GeometryGym as well. You only need the RevitIFC plug-in for this.
Let me know if you need any clarification.
Cheers
Nathan04-Revit-Feature-Generating a curtain wall_Curved.gh (24.4 KB)
Hi Nathan! Both ways seem working just fine. Thank You very much!
