Rotate multiple (groups objects) each by own center, 180º, any way?
-Igor
-Igor
Sounds like an interesting request.
The BoxEdit panel doesn´t recognize groups as entities, but it recognizes blocks.
I created a block for each group of cubes in the image.
Maybe that works for you?
if they are copies, you can copy them with history and simply edit the parent to edit the children.
if not, you can select them, use boxedit and make sure transform objects individually is checked.
It works!!! Thx guys!
