Not sure of the best phrasing here… But I’m wondering it there is a way in which I can have a command treat objects individually, rather than as a collective group.
For Example, Rotating all the object in a vertical array, so that they rotate around their independent mid points ‘individually’,… and not around their common selected ‘group based’ mid point.
Also, I’m not expecting to preform complex commands in this way. It would basically be commands such as rotation, and some sizing options… scaling, skewing, and similar…
