First time posting, need assistance with .gh file that I have been trying to achieve a draping with to aid in form experimentation. Image is not what I have produced but what I am looking to achieve. Any advice would be greatly appreciated.
Thanks in advance!
Drape Surface.gh (19.7 KB)
HS_Kim
January 18, 2021, 1:56pm
#2
You forgot to internalize your referenced curves and brep…
Anyway, you can check the topic below…
Have a go with this:
Fabric Simulation.gh (420.8 KB)
[image]
It uses the extra goal I posted here
which does the collision also with the edges not just the points (and also adds a tiny offset to make sure no bits still poke through).
Also - it might work better if it is possible to combine the meshes it is colliding with into a single closed solid. At the moment it is many parts - it seems to work, but I think it could potentially cause issues if the fabric gets stuck between overlappi…
Here ya go!
Drape Surface.gh (18.8 KB)
Amazing! The fabric simulation works very well at a finer level of detail. Thanks again.
That’s brilliant, thanks for taking the time to make that work David!
Same principle as the Fabric simulation, just simplified.
