Help! how to make a branching with 3 or more pipes in Grasshopper.
Thanks for the tip. Curious about Grasshopper.
I have done this but it needs a lot of rework but the logic is quite good. Could be terrific with xnurbs
thank you i will test it
Did you see the course ?
Does the axes of the tubes just stay in a plane ? Or in 3d ?
In first case it is quite simple to do.
I think you need a special Rhino version to follow that course (Rhino 6 “Undefined”)
I can check I am a member.
Cracked version
