Hi everyone,
I want to have branches based on nodes and each branch contains elements that reach that node…
I don’t have any idea…Do you have any suggestion?
Thanks in advance
You will find many resources here. Some links
Hello everyone, I have a simple question regarding meshes and subd objects.
I am trying to connect a group of joint and disjoint curves with multipipe, then convert them into meshes. The component works just fine event with thousands of curves, but I am having a problem separating the subd and meshes. What I need is to have separate shapes based on the intersection of the curves.
So for the curves seen in the image, I would like to have 8 mesh, but multipipe creates 1 subd object for all of th…
Help! how to make a branching with 3 or more pipes in Grasshopper.
[branch]
is it possible or does anybody know a way to generate a MultiPipe Node with different pipe sizes in Grasshopper or RhinoPython?
I want to interpolate a Node out of different pipes.
[image]
The component works perfect with one pipe size but I have to work with different diameters for each curve.
Thanks a lot!
I had this same problem before. I think you are looking for the proximity 3D node. Just input the range of radii and you will find the topology with the indices of the neighbor nodes.
