Help, GH Shatter Multiple Curves
Hi Guys,
im stuck on something simple.
I would like to split the attached curves at their intersections and then join them together into a closed curve.
any help greatly appreciated.
ShatterQuestion.3dm (84.8 KB)
ShatterQuestion.gh (7.8 KB)
Here are a couple of options.
One uses Python, using the Rhino common method to Create Boolean Regions.
ShatterQuestion_v2.gh (16.2 KB)
If you want just the intersections use Multiples intersections & Shatter component from Fennec addon
If you want regions you need Clipper addon and Region component from Fennec addon
ShatterQuestion.gh (21.4 KB)
Awesome thanks Adam, your a legend.
both worked well in my definition.
I need to get into Python, looks very useful.
Thanks Seghier, your logic also worked.
the Fennac addon looks interesting, thanks for the heads up
