Create regions from curves intersection
Hello guys,
I am trying to get the regions from the intersection of all those circles, I searched on the web but I am unable to find how to do this :
Please help !
Thanks
g1.gh (6.0 KB)
This is a problem that has come up before, and has a limited number of approaches.
Using GH:
In your example, because it is not that many lines, and is reasonably simple, you could just make a bounding (union) box around your geometry, and split the resulting box surface using the curves. This approach doesn’t scale very well, (performance wise), when the curve numbers/complexity increase.
Or…there are some custom scripted options as well. I remember seeing something on the old GH site that was pretty robust, using half edges…I think it was a custom VB component …I can’t remember.
EDIT: It was here!
Using Rhino Commands:
If you bake the geometry into Rhino, you can use CurveBoolean->Select Curves->DeleteInput=None, CombineRegions=No, Output=Surfaces, (click to accept), then click AllRegions and enter. (Rhino 6).
It’s very fast and, so far, seems to hold up pretty good against complex/high number of curves.
The CurveBoolean Command functionality, as described above, is not yet available in GH. I am hoping that is is exposed in RhinoCommon in some future release.
If you want all the pieces, does this work for you?
g1-2.gh (9.2 KB)
@chanley
Thanks for your answer, I hope it will be implemented in GrassHopper
@akilli
Thank you so much, this is what I needed !
This is beautiful.
Another approach:
or from Fennec:
Thank you for suggesting Surface Split, I was able to succeed in splitting a bunch of intersecting circles. I was unable to install Fennec that another user suggested (I’m on Mac, and from a bunch of forum posts Fennec isn’t working in v8), but your method worked like a charm – and very fast, too! :heart:
