I’ve read in a number of forums that you shouldn’t use the plan view anymore because it is a bit archaic and you should use the real time engine and export.
I was wondering if there is a way currently of changing the hatch pattern of the cut in hidden view to a solid color or something else then because in the plan view function you can but it takes forever to load.
Thanks
