Grid lines are not considered as reference object
Hello @Japhy…!
I was trying to draw dimension lines for Revit Grids using RIR. I have noticed Add linear Dimension component does not consider Grid lines as a reference object. The only way I solved this issue, was by converting the grid lines into Detailed lines (using Add Detail Line Component). Do you have any idea why grids lines are not considered as reference objects?
Hi Muhammad,
I’m seeing this as well and will get it on the list. Thanks
Thanks @Japhy for your response. But with this solution we have another issue. As the dimension line is drawn with refrence to detail lines so when I hide the detail lines in my model it also hides the dimension lines.
@Japhy Hi I wonder if there is any solution to this? We still observe this issue in 1.228962.17228 Thanks!
Hi Zhexiong Chai, that is still an open issue.
Do we have plans to solve this in the near future? Most of the time you always want to tie the dimensions to a grid line.
Hello @Japhy, I also faced that issue. It took some experimentation before I found my way to this forum. It would be great if you could add this functionality. :pray:
@Japhy
I’m waiting for this issue to be resolved.
