Add Detail Line not working
Hallo All,
I am wondering if someone know why the add line component on Rhino Inside Revit
doesn’t work on some computer setup (my other comp works), I already update my RiR but no luck,
error message (1. Object reference not set to an instance of an object.)
thank you
Hi Indra,
detail lines work only in certain views in Revit. Where are you trying to add it?
Hi Ruta,
i am using RiR on Family File, and using active view also doesn’t work, the thing is I am running the same script on my other computer (home computer) and it works, I wonder if this has something to do with something that I need to to update (IE, my .Net?)
as a background, I created a Profile generator for my Vertical Structure (Section Wall) using the Sweep method, it’s a pity that it works well on my home comp, but not on my office setup
Hi Santosa,
this is is a .NET error. Cool that you said that it doesn’t work on your office PC and it works at home.
Here you have a proof that it is a .NET error.
i have a feeling this might be the problem, but very hesitant to reinstall my .net. but since you said so now I will try to reinstall it. thx !
apparently updating the .net isn’t working also
Try isolating the edges with a List Item component, there may be something going on with the geometry.
Hallo Japhy,
I also tried this. i have no luck :smiling_face_with_tear:
Hi Indra, Can you post your About info and I will try and replicate. Thanks
Hallo Japhy,
thanks for your reply,
attached Requested About Info,
I have also attached my script for your convenience
(I have an idea to make a workflow that allowed me to draw a principal section in Rhino and transform it into Vertical Wall Sweep in Revit) I hope RiR will have a component to make a profile family and construct a wall using a profile I the future,
thx !
[Window Title]
Rhino.Inside - About
[Main Instruction]
Rhino.Inside© for Revit
[Content]
Rhino.Inside Revit: 1.16.8620.27572 (2023-08-08T15:19:04)
[Expanded Information]
Rhino: 7.32.23221.10241 (Rhino 7)
Revit: 2022.1.3 (22.1.30.34)
CLR: 4.0.30319.42000 (4.8.9181.0)
OS: Microsoft Windows NT 10.0.22621.0
about Info
Vertical Wall Sweep Generator_V2.gh (24.4 KB)
Vertical Wall Sweep Profile Line_V2.3dm (189.0 KB)
Hi @Indra_Santosa,
This is fixed on v1.17, but keep in mind that not all family documents allow you to create Detail Lines.
Hallo @kike ,
I installed the new update, but also had no luck,
[Window Title]
[Main Instruction]
[Content]
Rhino.Inside Revit: 1.17.8620.27747 (2023-08-08T15:24:54)
[V] See details [Web site] [Read license] [See source code] [OK]
[Footer]
Press CTRL+C to copy this information to Clipboard
My .Net version
I Tested on my Coleague computer with this version below, and it works.
[Window Title]
[Main Instruction]
[Content]
Rhino: 7.34.23267.11001 (Rhino 7)
Revit: 2022.0 (22.0.2.392)
Could you share an screenshot of the red balloon message?
Is it the same as before?
It would help if you share the rfa file of the family were you are trying to create a detail line.
hallo @kike,
yes, unfortunately, it’s the same error,
Attached .rfa and .rft
This is the RFA
Family1.rfa (380 KB)
The RFA Comes from this family template (I zipped it since it’s not possible to upload .rft?)
Metric Profile.zip (351.3 KB)
Apart from this issue, may I know if there are other ways to create a Profile in RiR, I tried to use the Create Family component but apparently there is no Profile in the category section, or is there another component that I can use to transfer my rhino/grasshopper line to a .rfa file?
I have tried in a profile family and was getting same error using the current public release… so for the meantime you can try the below component to add curves to the profile family keeping in mind it doesn’t allow object tracking.
RiR_Profile Family Add Curves.gh (10.3 KB)
@Indra_Santosa,
Please update again to the latest v1.17, we had a problem with the deployment system and it didn’t serve you the latest.
Hallo Tarabishy,
Thanks for helping! Your script works well, I can generate the detail line.
many thanks !
Hallo Kike,
The update works like a charm ! many thanks ! now i can sleep well…
thanks all for your time in helping me out !
@Gregor_Ruta @Japhy @kike @M.Tarabishy
see u in other RiR topics
