Greater Control with Surface Morph
Because it is a trimmed surface. Nurbs are evaluated by their untrimmed UV domain for most things in Grasshopper. There is no predictable way to tile a trimmed surface as there is with an untrimmed surface which has 4 sides, so what would you expect the results to be? In other words, how would you tile a circle with square tiles?
If you really need to use this untrimmed shape then I would use Rhino 7 WIP, convert the shape to mesh, quad remesh it, and use Twisted Box Mesh.
The other option is run ShrinkTrimmedSrf command on your surface to get the underlying untrimmed surface structure closer to the trimmed surface, then morph your modules, then trim the modules with the surfaces trim edge.
I tried to open your file but it took too long to open. I suggest reading some of these topics:
Trimmed Versus Untrimmed Surfaces
Lastly, turn on the control points of your trimmed surface and you will understand what is going on.
