I am trying to box morph a tile module but instead of morphing it is just scaling and orienting which too isnt perfect. See the script and the snapshot.
Query Script.gh (423.4 KB)
if you provide Breps to the Box Morph component, it will just calculate their bounding boxes and work with those (or, at least, I have that memory from Rhino 7)
because you actually need to morph a base Brep into twisted boxes (skewed boxes, not necessarily 90° angles) one way might be to calculate and provide destination twisted boxes to the Box Morph (and to do so you, one way is to use the 8 corner points in the right order)
as the initial bounding box was morphing weirdly, I also rebuilt it using a twisted box: but that is just for the sake of explanation, not the right way to do things (you will see I had to reorder points for the starting brep’s bounding box, but in reality I believe you should create its bounding box using the right input plane)
the Morph is applied only to a small range of destinations (sublist, 0 to 300 domain) otherwise my laptop fries ![]()
by the way, Point List to the deconstructed bounding box is one of your best weapons to understand what’s going on under the hood: point order for start and destination vertexes should be the very same
Query Script_Re.gh (435.7 KB)
Thanks @inno. That was great help !
