Good morning,
Using grasshopper I’m trying to let a three-pieces wooden stick drop from an high just from a gravity effect, to observe how it falls and how the three pieces interact with each other once on the ground. Furthermore I would like to ask you if it’s possible to create a series of falling objects like this, falling one after the other in different timings, and see the way the stack once fallen. Attached you’ll find the first draft file I was able to create. I think the problem could be the fact I only defined a single ground level without taking in consideration the other objects.
I’m just a beginner with the program and would really like some help.
Thank you in advance
Agnese Blanca
Ramo caduta in serie.gh (189.8 KB)
