GPU No Ground Shadow with OpenGL (Bug?)
It seems that ground shadow does not appear using OpenGL in ‘Show shadows only’ mode However, it does work in ‘Use a material’ mode and works for both modes using the Direct3D technology.
Thanks
Rhino 9 SR0 2026-2-3 (Rhino WIP, 9.0.26034.12305, Git hash:master @ f10eb7a75f4fc041d932b4ee5c7a6367183ae4eb)
License type: Commercial, build 2026-02-03
License details: Cloud Zoo
Expires on: 2026-03-20
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 9.0.12
Computer platform: LAPTOP - Unplugged [47% battery remaining]
Hybrid graphics configuration using OpenGL
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 12-1-2025 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA RTX A1000 Laptop GPU (NVidia) Memory: 4GB, Driver date: 10-29-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.80
Integrated accelerated graphics device (shares primary device ports)
  • Laptop’s primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-29-2025
Driver Version: 32.0.15.8180
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\KeyShotRhinoPlugin (78243fe3-17a0-4865-b713-88b4c224c48c)\1.5.0.0\KeyShotRhinoPlugin\KeyShotRhinoPlugin.rhp “KeyShotRhinoPlugin” 1.0.0.0
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26034.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26034.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26034.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26034.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26034.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26034.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\Calc.rhp “Calc”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Display issue.3dm (2.9 MB)
Hi Sach -
This is what I see when I open your file:
I take it you are seeing something else?
The ground shadow doesn’t show at my end with OpenGL in WIP
The same model in R8 works as expected – with the shadow.
Hi Sach -
I would start by updating the GPU drivers using the “clean install” option.
I’ll try that. Any idea why it’s working in R8 though? Thanks
Every version of Rhino leans on OpenGL more, so more to go wrong with drivers.
Also OpenGL is just about dead so V9 is switching to DirectX, that’s probably what you’re actually running, so that’s a whole new set of bugs.
@wim It’s the same after updating the both graphics drivers…
@JimCarruthers thanks.
I switched to OpenGL is because I thought the model was a bit zipper to spin around the viewport. I’ll just keep it set to Direct3D.
It may be a bit zippier for now. The current focus for Direct3D is to make sure everything looks correct. Once that is done we will focus on areas where we can try to improve the speed.
Okay, thanks
