Rhino 8 - shadows visible behind Grasshopper geometry
I searched the forum but did not find any solution or info about this problem. In Rendered view, Rhino shadows are drawn in front of Grasshopper geometry (with Default Material applied through Custom Preview). When I turn off Rhino shadows (in Display Options), the geometry is opaque. When I turn on shadows, the Grasshopper geometry looks weirdly transparent, but it’s only the shadows behind it that are visible.
Is this a bug or did I miss some display setting in Rhino or in Grasshopper?
See attached photos with shadows turned off and on.
No ideas? I still haven’t found any solution to this problem.
Please run the Rhino command _SystemInfo and post the result in a reply.
Thank you, see system info below.
Rhino 8 SR4 2024-2-13 (Rhino 8, 8.4.24044.15001, Git hash:master @ 5d3f86ffffae3c2ed84d21147c008b3907a40a2e)
License type: Commercial, build 2024-02-13
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.17
Primary display and OpenGL: NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 11-29-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.29
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 11-29-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.29
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-29-2023
Driver Version: 31.0.15.4629
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.4.24044.15001
Lets start by having your GPU driver updated to the latest. At the moment of writing that would be NVIDIA Studio Driver | 551.61 | Windows 10 64-bit, Windows 11 | NVIDIA
Choose to do a custom/advanced install and check the clean installation checkbox before continuing.
Also, Rhino 8.5 is released now, it would be good to update to that after you’ve handled your GPU driver.
Let me know if that helped.
Thank you Nathan, updating both the GPU driver to 551.61 and Rhino to 8.5 did indeed solve the problem. Now it works as expected.
