Shadows don't show up on ground plane
Rhino stopped showing shadows on the ground plane of my files. I had no problem with this up until now. I have the ground plane turned on, the shadows on, even in the display modes settings.
Also when i try to open a file which until this morning showed perfectly the shadows on the ground plane and the render worked just fine, now when i try to open it rhino just crashes. I also tried resetting it and nothing.
post your file and systeminfo? hard to help without it.
This is the the system info and also I uploaded just a random file with a box and you can see that even on renderd display mode it doesnt show shadows:
Rhino 8 SR15 2025-1-19 (Rhino 8, 8.15.25019.13001, Git hash:master @ 74164bdf5469c2f269746857c54b8c44b74c7b24)
License type: Evaluation, build 2025-01-19
License details: Stand-Alone
Expires on: 2025-05-06
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: LAPTOP - Unplugged [96% battery remaining] ~82 minutes left
Primary display: Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 8-19-2024 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA T600 Laptop GPU (NVidia) Memory: 4GB, Driver date: 6-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.78
Integrated accelerated graphics device (shares primary device ports)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 2.1
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-10-2024
Driver Version: 31.0.15.3878
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.15.25019.13001
ShadowsProblem.3dm (37.3 KB)
Hi Kaltra -
Why did you set the OpenGL level to 2.1?
The slider should be at “Max OpenGL Available”.
open gl 2.1 is the issue.
drag this slider all the way back to the left.
Also run your laptop plugged in with Rhino to keep it from switching to the intel card (the less capable one)
you may also want to follow these steps-
shadows look fine here-
