Ghgl vertex color?
Does anyone know to get vertex color in ghgl like gl_Color?
vertex could be got from " layout(location = 0) in vec3 _meshVertex; " , but how about vertex color?
Do you want the vertex colors that are already set on a mesh? This is currently not available, but I could probably wire it up pretty quick.
Yes, input mesh already has vertex color.I’m looking forward update.
I just updated ghgl to version 0.3.5 which you should be able to install from TestPackageManager in Rhino.
This includes support for mesh vertex colors. A sample using this in GhGL can be found at
https://github.com/mcneel/ghgl/blob/master/src/tests/vertex_colors.gh
Oh, Thank you, this is what i want.
Thank you again !
Hi @stevebaer, since edit code doesn’t work, could you add a diffuse colour to prevent the magenta shading please, thank you
I would rather just fix the code editor instead of creating a work around
I think Rhino 7.6 will fix the issue with the code editor falling behind grasshopper. Please update to 7.6 when you get a chance.
