Hey everyone,
I have set of doors in my project and I want to get the geometry of openings they create on the wall. Is there any way i can achieve that?
Hey everyone,
Hi @mucahitbgoker,
You can use the ‘Exclude’ input of ‘Element Geometry’ component to do something likes this.
RiR-OpeningGeometry.gh (23.1 KB)
hi @kike ,
thanks for replying this fast. I havent been able to achieve what i want using the definition you shared. You can see it from the image below. Also I have attached my sample file. Thanks for helping!
Project1.rvt (9.2 MB)
Well you need to filter out walls without opening first.
What about this?
thanks @kike,
it worked just fine.
Unfortunately the method can’t work for link file. The link elements can’t be excluded.
I think this looks like a model category picker. Instead of using that, can you try Query Categories and connect the linked document in the document input. I think Built-In Category assumes you are trying to reference from active document by default.
BTW, Model Categories picker replaced long time ago. Which version of RIR are you using?
I tried it on 2022. Maybe this might be an issue related to the Revit version. maybe @Japhy can help.
I can confirm that this problem exists in R2018.
Thanks for testing, I don’t have 2018 anymore & there is discussion to how much longer we will support it.
This issue looks to be about the document linking in the API which i know has a fix coming, not saying it will fix this, but hopefully. I believe it should be available in next Tuesdays RiR daily build.
