GeometryGymCsi assigned loads not in SAP model
Hi to everyone,
I recently started using Rhino-Grasshopper and the GeometryGym plug-in to perform structural analyses via SAP2000.
I started with a very simple case: a simply supported beam with a concentrated load in the middle. I created the model step by step by following the tutorial available online. Although I have performed all the steps, once I “bake” the model and view it on SAP, there aren’t the loads (in my case a load concentrated applied in the middle of the beam), except for the self weight. Also, I don’t get any results from the analyses. Where am I wrong?
I attach the screenshots of the canvas and SAP.
Thank you so much.
Hi Matteo,
Can you please post the gh script? Or share privately?
It takes time to try and replicate from screen shots and I could easily miss the issue that might cause the behaviour.
Thanks,
Jon
here is the script. Thank you very much for your help!
Caso 1 GeomGym.gh (21.7 KB)
