"From" Snap and ortho/shift
hi,
recently found that move, movesurface… has a problem with “from” snap. i cannot select the “From” point perpedicular or holding shift even F8 does not work.
regards.
Hi Rasim - so the scenario is, you place the ‘Point to move from’ in Move and then want to place a base point for the From snap ortho to that first point, is that correct? I see that this does not work but SmartTrack can help here.
Hi pascal,
yes thank you the smarttrack helps. i just want to point out the odd behavior.
regards,
Rasim
