Hello
I’m a new Rhino user.
I’m trying to figure ut if there’s an option to snap FROM a specific point (like in Autocad). For instance, in case I want to move a poly line single edge from a specific reference point to another point by a specific number of units, how do I do it? Thank’s, Inbal
You can either use the “From” object snap - available in the osnap toolbar palette or type it at the command line - or in many cases a relative coordinate displacement will do the trick with rX,Y (Autocad uses @, works in Rhino too.)
HTH, --Mitch
Thank’s a lot
