Commands with shift ortho constraint
Hi All,
I am trying to check if in the RhinoCommon SDK there is any automatic way to have a GetPoint that accepts the shift modifier key to constraint the input along the ortho direction (as the Line, Curve and other commands do).
Do I have to implement this myself?
Thanks a lot
Alberto
Hi Alberto,
Well this should be on for all new instances of GetPoint. But you can set this explicitlly by calling GetPoint.PermitOrthoSnap. Note, ortho only works if you set a base point using GetPoint.SetBasePoint.
http://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Input_Custom_GetPoint_PermitOrthoSnap.htm
http://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Input_Custom_GetPoint_SetBasePoint.htm
Does this help?
– Dale
That’s a good tip :wink: we are not setting the base point in our command, that was the missing step.
Thanks a lot Dale! Have a great day
Alberto
