i’m using the latest Rhino Version 5 and I have the following problem in the 32- andt the 64-Bit Version.
All the Time rhino works well and without stutter, but then suddenly the pc hangs up completely. Not only rhino crashes - nothing worksany more. Even the mouse pointer can’t be moved any more. These complete crashes exist only while I use rhino. These occur not at fixed times, but at random. Since I use my pc for the work, this is clean (there are not many programs installed on it). Rhino itself is also freshly installed. I have no other plugins installed.
My hardware configuration is:
processor: Intel i5-4570 with 4 Cores @ 3,2Ghz
ram: DDR3, 8GB
graphics: Intel HD Graphics 4600 with 2,1GB (onboard graphic card)
Windows 7 64 Bit with aktual updates
Here is a list of the active plugins. I have only the neon renderer post-installed. But the problem occurred already before.
How do I run rhino in safe mode?
Hi, I have an on-board graphics card, an Intel HD Graphics 4600 with 2.1GB. I just saw that the graphics card driver was not up-to-date (there was a version of 2013 installed.)
In general, an own graphics card (not on-board) probably makes more sense. This I will also test, if the problem persists.
Nevertheless, the error is strange because not only the program crashes, but the complete pc hangs.
If I am smarter, I will report, thank you so far for the help.
