Form Finding Karamba error
-solution exception could not find node at where support index 0 is attached
I’m attempting to form find by incorporating beams, supports, and loads. I’m attempt to apply element stresses, support reactions, and node displacements using Karamba but I’m getting errors.
Here’s my model
structurestake2.3dm (143.7 KB)
Untitled (1).3dm (38.1 KB)
structurestake2 (1).gh (69.0 KB)
Hello @Dan_Benaroch,
in the GH-Definition the scale of the structure is wrong by a factor of 1000 I think. K3D assumes geometric input to be in meters (or feet) by default.
The nodes where you define nodes are not part of the structure defined via the lines input.
– Clemens
